Just replaced the Conti tires with Yokohama A.Drive AA01. The CC lasted 50k (actually can go more, but two tires were in not so good condition). For standard size, 195/60/15, not much choices and prices are a bit on the expensive side.
I chose the Yoko because it is rather affordable. RM190/piece. Compared to Michelin Primacy LC, it is RM250/piece! The Yoko is slightly noisier than the Conti when they are new, but handles a lot better. Less flex during cornering and doesn't squal easily. Better braking too. Haven't had the chance to try in pouring rain, but I can assume it will perform much better than the conti because of the wide grooves.
Conclusion, if you want a better tire than the stock, you have to fork out more. Otherwise, the best option is the Conti Comfort. But then again, the conti is not cheap either. RM210 per piece if i'm not mistaken.
Persona tyres
clorox
, Jul 07 2008 01:23 PM, 21 replies to this topic
