Ps/rpm
hwk
, Mar 26 2009 06:54 PM, 23 replies to this topic
Posted 27 March 2009 - 07:04 PM
QUOTE (hwk @ Mar 27 2009, 04:44 PM) <{POST_SNAPBACK}>
that i know so how to compare stream 1.8 with accord 2.0 cos the weight show kg
Bradeer
As I said, 1000kg = 1 metric tonne.
Posted 27 March 2009 - 07:15 PM
QUOTE (hwk @ Mar 27 2009, 04:59 PM) <{POST_SNAPBACK}>
btw i've to check Kerb weight (kg) or Gross vehicle weight (kg)
Kerb weight is the total weight of a vehicle with standard equipment, all necessary operating consumables (e.g. motor oil and coolant), a full tank of fuel, while not loaded with either passengers or cargo.
Gross wt = kerb wt + passengers + cargo
Kerb wt = BTM- berat tanpa muatan, Gross wt = BDM- berat dengan muatan.
Usually, kerb weight is used.
Posted 27 March 2009 - 07:36 PM
ok i got it now...
but i've test drive civic 1.8/ 2.0 (i can't remember) clock 30k km at sg besi, and stream (new) at other branch
according to
Civic, 1.0/1.2 x 174 = 144.99PS/ton
Stream, 1.0/1.5 x 174 = 115.99PS/ton
but i feel civic less power, and the steering very heavy
according to
Posted 27 March 2009 - 09:14 PM
Due to Stream's heavier body Honda could have re-tuned the TCU (Transmission control unit) and or with slightly different ratios causing the heavier model have good pick-up or responsiveness in low or mid revs but mebe higher FC... Maybe some experts cud input in on this.
Cruiser
Posted 27 March 2009 - 09:18 PM
It could be due to gearing.
Anyway, since you failed to correct your post, I will help.
All the figures you qouted are not for power(PS), but are for torque(Nm).
These are all max. torque in Nm-newton metre. The max. power output in PS are in bracket.
altis 1.6 = 145Nm @4400 (? I don't know)
city 1.5 = 145Nm @4800 (120PS @ 6600rpm)
stream 1.8 = 174Nm @4300 (140PS @ 6300rpm)
accord 2.0 = 189Nm @4300 (156PS @ 6300rpm)
civic 1.8 = 174Nm @4300 (140PS @ 6300rpm)
But the method of calculation remains the same.
For eg, Civic's specific output = 1.0/1.8 x 140 = 77.8PS/L
and its power-to-weight ratio = 1.0/1.2 x 140 = 116.7PS/ton
Posted 27 March 2009 - 09:50 PM
If the Civic does indeed has a specific output of, 1.0/1.8 x 174 = 96.7 PS/L,
then it's in supercar territory liao lor.
Only one Honda engine has a specific output of more than 100PS/L, and it's the type R.
For eg, the FD2R produces 222PS from a 2.0L engine, giving it a specific output of 111PS/L.
Ferrrari's latest California produces 453hp from a 4.3L engine, so it's specific output is 105hp/L.
So the mighty type R has a specific output higher than a Ferrari.
Posted 28 March 2009 - 09:09 AM
erm...i feel like someone just dun understand what all is this about... itchi,no matter how details u explain there is still alots of comparison that he dun understand...but i really like ur details explaination n comparison...
Posted 28 March 2009 - 09:16 AM
QUOTE (Popcorn @ Mar 27 2009, 09:14 PM) <{POST_SNAPBACK}>
hi popcorn,
how r u?so long never see ur post....
well,u r right...but someone might dun mind if the FC is high if there is performance,but some rather dunwan performance n prefer low FC...but where to get both in advance? no one is perfect le..friend...
Posted 28 March 2009 - 11:08 AM
yeah i'm know nothing about car even i've bought 7 cars in 10 years
now planning buy a honda car but still no idea get what car... civic? accord? crv? stream?
