Ps/rpm
hwk
Posted 26 March 2009 - 06:54 PM
hwk
  • 211 posts
I saw honda 1.8 and 2.0 car almost with 140ps, so just want to know which it more powerful, i mean the max horsepower
-140@6300
-136@5600
-132@6000
sorpoh
Posted 27 March 2009 - 09:43 AM
sorpoh
  • 428 posts
QUOTE (hwk @ Mar 26 2009, 06:54 PM) <{POST_SNAPBACK}>
-140@6300
-136@5600
-132@6000
no adays ppl normally wont see hp...they will go for torque..corect me if i m wrong wink.gif
hwk
Posted 27 March 2009 - 11:07 AM
hwk
  • 211 posts
really? so we've to check Nm(kg-m)/rpm?
Nm/rpm
-174@4300
-190@4200
-189@4300
-182@4000
-170@4200
which more powerful? like pick-up...
Itchibawa
Posted 27 March 2009 - 12:05 PM
Itchibawa
  • 2,384 posts
PS = hp in metric system
1PS = 0.986 hp
The difference is too small to be of any significance.
In normal daily driving, when the engine typically rev in the low to mid rpm range, torque is more important than hp/ps.
A dynograph is more useful than a quote of max hp.
hwk
Posted 27 March 2009 - 01:36 PM
hwk
  • 211 posts
so if...
altis 1.6 = 145@4400
city 1.5 = 145@4800
or
stream 1.8 = 174@4300
accord 2.0 = 189@4300
civic 1.8 = 174@4300
darreltian
Posted 27 March 2009 - 01:55 PM
darreltian
  • 4,823 posts
other than the mentioned above, u need to consider also weight, gear ratio, wind drag coefficient to name a few...
Itchibawa
Posted 27 March 2009 - 04:06 PM
Itchibawa
  • 2,384 posts
QUOTE (hwk @ Mar 27 2009, 01:36 PM) <{POST_SNAPBACK}>
so if...
city 1.5 = 145@4800
The only thing you can derive from this is the specific output of the engines, ie, the power output per 1000cc (or 1L);
The Altis 1.6L engine's specific output = 1.0/1.6 x 145 = 90.63PS/L
The City 1.5L engine's specific output = 1.0/1.5 x 145 = 96.7PS/L
So the smaller City's engine has a higher specific output as compared to the Altis.
or
The same with these sets of figures;
The Stream 1.8 and the Civic 1.8L share the same R18 engine. So they have the same PS rating;
1.0/1.8 x 174 = 96.7 PS/L
As for the Accord, 1.0/2.0 x 189 = 94.5PS/L
These figures will not tell you how well the car will perform, as the weight of the car is not known and factored in.
In the other words, the more important power-to-weight ratio is not known.
For example;
The Civic weigh about 1.2 tonnes, while the Stream weigh about 1.5 tonnes.
So the power-to-weight ratio per tonne, 1000kg is;
Civic, 1.0/1.2 x 174 = 144.99PS/ton
Stream, 1.0/1.5 x 174 = 115.99PS/ton
Therefore, although the two cars have the same specific output, the Civic has a better power-to-weight ratio.
So, obviously the Civic will perform better than the Stream on the road.
hwk
Posted 27 March 2009 - 04:19 PM
hwk
  • 211 posts
thanks for reply, so is that mean city more powerful than altis 1.6, and civic 1.8 better than accord 2.0?
Itchibawa
Posted 27 March 2009 - 04:35 PM
Itchibawa
  • 2,384 posts
QUOTE (hwk @ Mar 27 2009, 04:19 PM) <{POST_SNAPBACK}>
Yes.
Civic/Stream and City have the same specific output and tie for first.
Accord came in second and Altis last.
I editted my post after you read it to include power-to-weight ratio.
Please read it again to the end.
hwk
Posted 27 March 2009 - 04:44 PM
hwk
  • 211 posts
QUOTE (Itchibawa @ Mar 27 2009, 04:35 PM) <{POST_SNAPBACK}>
Yes.
that i know smile_approve.gif so how to compare stream 1.8 with accord 2.0 cos the weight show kg
