Optra 1.8lt - 100k Service Menu & Price
Posted 18 December 2010 - 12:47 PM
Timing Belt - RM600.00 (Original)
Tensioner A-Timing Belt - N/A (Bundled with timing belt)
Seal-CR/SHF FRT - N/A (Bundled with timing belt)
Seal-CM/SHF FRT - N/A (Bundled with timing belt)
Roller Guide - N/A (Bundled with timing belt)
Water Pump - RM160.00 (OEM)
O-ring w/pump - N/A (Bundled with Water Pump)
Tensioner A/Comp - RM180.00 (Original)
V-Belt RM60.00 (Bando - 6PK1890)
Oil Filter - RM16.00 (Original)
Spark Plug - RM30.00 (OEM)
Coolant - RM20.00 (Toyota)
Air-con Air Filter - RM35.00 (Original)
Brake Oil - RM15.00 (OEM)
Engine Oil - RM65.00 (Carlube Fully Syn 5W40 from Singapore S$27.00)
Valve Gasket (For engine top cover) - RM36.00
Surge Tank (The tank for coolent) - RM100.00
Absorber - RM180.00 each (OEM)
Posted 23 December 2010 - 11:37 AM
Bro.. the timing belt set tu mcm doubt aje original. Original Oil Seal aje dah dekat RM100 sebiji. Aku suspected depa bagi OEM aje. Better check betul2 bro.
Posted 28 December 2010 - 10:57 AM
2011~current - Aveo5 1.5
2010~current - Optra 1.8 LT
2005~2011 - MyVi 1.3 EZi
2002~2005 - Wira 1.5
Posted 30 December 2010 - 04:47 PM
Posted 30 December 2010 - 05:40 PM
Iye.. tgk listing kat atas tu. Kalo nk details.. contact me at 012-2126547.
Posted 03 January 2011 - 09:25 PM
My Optra 1.8 refuse to start now. Very funny. Just serviced few days ago and everything is ok. What could be the problem? anyone can suggest? FYI new battery installed 2 months ago. Am going to call Zaki at Shared Auto by tomorrow morning...
Posted 04 January 2011 - 10:50 AM
Ok. Thanks.
Posted 04 January 2011 - 04:49 PM
It started in the afternoon as usual. Drive to Glenmarie right away. Went to the other Shared Auto and met Fauzi. He diagnosed my Optra and it falls under "Mystery" categories. Maybe my Optra nak manja2 with me kot.
Posted 05 January 2011 - 11:12 AM
You may have want to have the mechanic to double check the battery contact, and have them replaced if possible. The battery contact may get rusted or corroded after few years and replacement / deep cleaning is necessary. Can also try this if helpful: http://www.ehow.com/...y-contacts.html
Posted 05 January 2011 - 04:17 PM
Thanks Dick, the battery contact is in good condition, no rusting, not corroded.
Appreciate your inputs
