Asked my technicain friend from PE SC cheras abt waja gearbox. They are
surprised that waja gb so far not many came back with problems. They thot
the waja gb would be problematic like the perdana gb but surprisingly no.
Abt the ECU, can we cover it up with plastic bag or something so that
water cannot go in??
waja gear box
rprabah
, Sep 22 2005 05:46 PM, 25 replies to this topic
Posted 16 November 2005 - 08:42 PM
you can try using my ecu and see got any difference or not. if got no
difference then i return your money lor.
Posted 16 November 2005 - 08:45 PM
i am not saying anything, but i used to drive a waja as well. and the ecu i
am having now is a brand new ecu. i used it for a month only. my old ecu
was fried when water from the air con went inside. i took it to proton edar
and indeed it cost me rm5k to replace the ecu unit alone.
at the end of the week, got a good deal on a fto halfcut. sold everything
but the ecu.
but the ecu.
Posted 17 November 2005 - 12:06 PM
Hi....all....
rprabah...
Cost for repair (change oil seal )include labour and some atf oil is
around rm 500. Better you check for comfirm what the problem. You can
call this number ( Koboi 012-9058172 ) for appoiment for checking.
This guy is familiar with proton problems. He also give resonable price
for repair. You can see his name at thred 'waja with abs problem'.
rprabah...
Posted 17 November 2005 - 12:21 PM
Dear: rprabah
Kindly check your main fuse box located in your engine there and refer to
the signal (E or G) a square fuse c wheather blowed?? because my waja
also facing the problem the Gear is not shifting and the N signal blinking,
many sc claim my gearbox and ECU have spoil but i not believe them my
gearbox always service in between 4 to 5 month and my ecu had protected
by a plastic to avoid from aircond water..... after change the fuse the
gearbox shifting back to normal ...by the way if not mistaken beside the ecu
there is a little square box it also related to the gearbox..
