Posted 28 February 2011 - 05:45 PM
Your original suspension gone?
going soon, 5 years now
change the bearing in the wheel 2 weeks ago
ABS is Actual BullShit, having it on my car is like admitting that I take viagra!
Posted 28 February 2011 - 05:47 PM
well, after 5 years is maintenance or new car........
Posted 28 February 2011 - 05:49 PM
not for now and no car in the market interest me
Posted 28 February 2011 - 05:52 PM
So it is maintenance.....
Posted 28 February 2011 - 05:53 PM
yeah.. still got a few more things to tweak to make it more fun
Posted 28 February 2011 - 06:14 PM
Posted 28 February 2011 - 06:19 PM
a set of adjustable, bigger front disc and caliper and steel braided hose
kohf1drive
Posted 28 February 2011 - 06:44 PM
ah koh....why sell your sustec rear absorber???
Mine rear is greber semi-adjustable
My front set improve propex gone soft already
I can't get a set take can last longer than 1 year
kohf1drive
Posted 28 February 2011 - 06:47 PM
Not bad, actually quite like it, but I have them in the rears only. Mine are old technology and can adjust spring rate only. The harder the springs the higher the car, the softer the springs the lower the car.
I kept it this way because I tried lowering the car, but ride is not acceptable and had problems with the drive shafts.
The rears have recently gone soft, but they are 10 years old already and have not been serviced before.
The fronts are OE suspension but sent to them for rebuild. Means they change the internal and strengthen the damping rate by 25% harder. In this 10 years the fronts were rebuild once after 4 years. They started to leak. First round they did sealed type so they have to cut it open again. Second time they build with removable seal like screw top. So far, have got soft slightly but no leaks so leave it first.....
How you drive?
All the bumps/uneven road you slow down?
Posted 28 February 2011 - 07:13 PM
you must be super fast driver.....
