My Naza Ria Engine Wanna To Convert To Cefiro Engine
danish09
Posted 03 August 2011 - 11:31 PM
danish09
smile_angry.gif Raya just around the corner..............i planned to install new Naza engine but the costing look like same convert to Cefiro engine...what do you think?
byebye2u
Posted 03 August 2011 - 11:53 PM
byebye2u
  • 2,805 posts
QUOTE (danish09 @ Aug 3 2011, 11:31 PM) <{POST_SNAPBACK}>
so many cefiro spec, if 3.0 then will probably have enough hp and torque to pull heavy Naza Ria around unless if the mechanic know how to use the same naza gearbox...kasi kawin enjin dengan gearbox.
it is more easier if donor engine come from a car that has almost same weight.........gear ratio problem.
ajoiauto
Posted 08 August 2011 - 11:51 AM
ajoiauto
  • 39 posts
hi danish09...
what happen to your old naza ria engine????
APEK
Posted 26 May 2012 - 10:38 AM
APEK
  • 579 posts
anyone here made the conversion?
i've converted my kia karnival engine with cefiro2.5 last year. timing chain. better fuel consumption. everything is perfect except for dryshaft issues. anyone face similar problem?
Posted 20 June 2012 - 01:23 AM
4798
  • 61 posts
done a lot of this convertion ..no problem at all. Depand the material you use for the driveshaft. plz feel free to call us 0122375631 : (under 3 garage) yr nazaria solution.
jason81
Posted 04 July 2012 - 10:33 PM
jason81
  • 56 posts
QUOTE (APEK @ May 26 2012, 10:38 AM) <{POST_SNAPBACK}>
most converted ria will have the drive shaft problem , because the level is different , the engine is higher than the wheel , so the driveshift is "sengek" when rotating.. try cut the spring to lower the car ..this is what my friend said
but i saw some workshop claim they have a custom made driveshaft ..
