ahwan308
Posted 30 April 2011 - 11:26 AM
UK has a different spec? I doubt so. Can we use the shorter version?
I think so and I prefer "UK spec'' because 28" blade can be fixed on the driver's side.
30" blade cannot [too long] unless u swap the arm [may be
lah... anybody had tried?]
Posted 30 April 2011 - 03:46 PM
Thanks ahwan...so to confirm..
On yours,
our drivers side - 28"
our passenger side - 26"
correct?
wipers can be swapped from left to right?
ahwan308
Posted 30 April 2011 - 05:42 PM
Yes and NO
Ori wipers Cannot. The wiper is designed to be fixed on the correct arm - i.e not interchangeable.
Third Party wipers CAN be swapped between left and right.
On my 308, I fixed the 28" wiper blade on driver's side as shown in the pic above.
Posted 01 May 2011 - 02:20 PM
Yes and NO
Thanks.
So I presume your driver's side is having 28" while passenger side is having 30".
Can you let me know where did you get those? Thanks.
ahwan308
Posted 01 May 2011 - 04:06 PM
Currently I'm using third party 28" blade on driver's side and 26" on passenger's side. Because the driver always need larger wiping coverage.
Pls take note: It is not advisable to swap wiper arms in order to accommodate original 30" blade on driver's side because the shorter arm on passenger's side will be too short to wipe water droplets above rain sensor. This wil make rain sensor useless.
28"/26" wiper blades frm
HERE 30"/26" blades frm
HERE
chargerguy
Posted 01 May 2011 - 09:45 PM
Uncle D,
Can we order 28" for both so both driver and passenger side will have balance coverage???
Thanks
Posted 01 May 2011 - 10:39 PM
HEREThanks. Your rain sensors still work as normal?
ahwan308
Posted 02 May 2011 - 05:58 AM
Can we order 28"...
Normally twin pack comes with different blade lengths; such as 30" x 26", 28"x 26"... etc.. but think v can buy single-pack blade of any length. Next time I'll order 2 pcs of 28" blades...
baru betul2 ngam!
http://www.wiperblad...e-wb120s28.html or probably we can dig out frm
HERE too.
If u don't swap the arms, 28"blade on passanger's side arm is long enough for the rain sensor. I advice u to buy 2 single-pack 28"blades as suggested by Chargerguy.
Posted 02 May 2011 - 04:39 PM
We could get 2 identical 28" wiper blades but the "spoiler" of the wiper will not conform the aerodynamic position...Uncle D...is this correct?
ahwan308
Posted 02 May 2011 - 07:54 PM
. ...the "spoiler" of the wiper will not conform the aerodynamic position...
Get the centralised spoiler type of wiper blades like these:
...which allow fitment to both left-hand and right-hand drive vehicles, as well as to vehicles with 'clapping' blades like our 308.
