High Pressure Pump Need To Be Replaced Due To Engine Fault
Posted 14 April 2013 - 11:14 PM
I received a bad news last week, i have the engine fault warning + depolution sensor warning, after sending to SC for checking, they told me i need to replace the high pressure pump which cost RM 2.5k (my car already out of waranty)
Would like to seek some inputs from you guys if this is a known issue? and i should proceed with the change? As this is not cheap. Previously i have depolution sensor issue and they just change solenoid valve. I just worry they keep changing parts and waste my money.
thanks!
Posted 15 April 2013 - 01:28 AM
thanks!
The HPFP is a known issues to certain batch. Get it check and diagnose at third party workshop to confirm as well as to get a quote on $$$...
1 cent
Posted 16 April 2013 - 08:50 AM
thanks!
Yes, go or a third party diagnosis. The mechanic usually has a checklist when those fault codes comes out and they will stop the moment they think found the solution (at your expense in this case).
My case after several trips was this pump that pump changed and end up a leaking air hose. WTF while they were replacing the 2nd type of pump i don't know what was it called, i gave them permission to replace all pumps whether its electric pump, fuel pump, water pump, air pump, hand pump or leg pump and i don't care so long don't have to come back so often.
Posted 16 April 2013 - 01:15 PM
thanks!
I have spare fuel pump. Let me know your chassis number if you are interested and I'll check if the part number is the same.
Posted 21 April 2013 - 09:06 PM
1 cent
hi chargerguy & pbm, thanks a lot for the advice. I will do that asap this week! i'm from Penang, I think will have problem look for 3rd party workshop that know Peugeot car well, any suggestion?
thanks again
hi bro blackdolph, thanks for u kindness. Mine is high pressure pump, same as fuel pump?
Posted 21 April 2013 - 09:30 PM
thanks again
You can try spanar pantas at malvest building (alliance bank at corner) near Bj complex.
http://www.peugeotcl...v...?f=17&t=162
Posted 22 April 2013 - 12:00 AM
thanks again
High pressure pump. That's the one I have.
Posted 25 April 2013 - 10:17 PM
thanks so much bro! I really appreciate ur help!
Posted 13 September 2013 - 08:20 PM
Posted 26 September 2013 - 09:51 PM
thanks again
I was told by my fren that there is 1 workshop near mobil petrol station in glugor is specialized in peugeot car
