Proper Maintaince Yamaha Lc135
reuters32
Posted 19 August 2009 - 08:34 AM
reuters32
  • 96 posts
cukup mustahil rantai dan sprocket boleh tahan 100K
My bike has chain COVER set also lasts only 30,000km maximum before putus and jatuh.
Anyway, limking u masuk JB - Spore hari - hari ke?
Your LC135 is the brand new batch ? Msian plate or Spore plate?
I also learn new thing from LimKing which is gear 1 bawa slow slow then baru bawa laju.
Kalau macam ini shall i buy LC135 fuel injection...now spore is selling the model.
v2
reuters32
Posted 19 August 2009 - 08:47 AM
reuters32
  • 96 posts
lim king has 5 vital points for us to learn
1. traffic junction always shift gear to neutral
2. gear 1 always bawa slow slow at the beginning of ride
3. Engine oil : Shell VSX & every 2K - 2.5K km per change
4. Sparks plugs : NGK & every 6K - 7.5 K km per change
5. Chain : Oiling every morning before journey with 3rd grade new engine oil ( cheapest one RM7-RM8 )
v2
reuters32
Posted 19 August 2009 - 09:51 AM
reuters32
  • 96 posts
lim king,
sila jawab soalan berikut
1. where u buy the bike? which shop? i also want to get from same shop.
2. u add in / top up water for batery?
3. morning start ade tarik choke?
4. whenever u star bike u use kick start? tendang kaki?
5. what brand oil u put for chain ? cheap RM7 shell ?
6. what petrol u use ? RON grade and brand ?
v2
limking
Posted 19 August 2009 - 10:50 AM
limking
  • 2,887 posts
QUOTE (reuters32 @ Aug 19 2009, 08:34 AM) <{POST_SNAPBACK}>
Why not you cuba ikut cara saya , nanti tenguk bagaimana ? Tiap taip hari boh minyak atas rantai sebelum berlepas , minyak hanya boh sekali sehari . Satu botol minyak murah litre pun boleh tahan 1.5 -2 bulan , tak banyak belanja juga. Beside that , daily I do a check on the chains to be sure it's not too loose or too tight when putting the oil on the chain manually without the engine started .
Mine LC135 is Malaysian registered and am not sure whether it was a newew batch or the older patch . Anyway it's 3 years plus on the road already .
Yah . I travels to S'pore from Pasir Gudang 5 days per week . Daily mileage is around 140km .
limking
Posted 19 August 2009 - 10:58 AM
limking
  • 2,887 posts
QUOTE (reuters32 @ Aug 19 2009, 09:51 AM) <{POST_SNAPBACK}>
lim king,
I bought from shop in JB town opposite Maybank when my last bike kaput instead of repair thought I change into a newer one .
Using M/F battery .
Only like cold raining morning need to tarik the choke .
Sometime tendang and sometime electric start ,morning tendang ,after S'pore custom elecric start ,
Chapalang oil ,any cheap oil will do on the chain .
Last time used Shell V power and now since the sales of V power is ceased , guess I'll use back Petronas Primax 3 .
reuters32
Posted 19 August 2009 - 11:22 AM
reuters32
  • 96 posts
excellent lim king
i am in tampines.
thanks for answering
more questions
1. do u have clutch manual ?
2. what is fuel consumption for 110km/h and above. ! litre can last how many KM
3. how come u so good in biking but yout last bike kaput? last bike was honda wave 125 ke?
4. u have givi box?
5. ur mentol lampu depan u change to halogen ?
6. how come u never change the air filter ..... i always change mine at every interval 10,000km
7. I want to buy LC135 fuel injection with manual clutch in spore pasal I orang sana. Recommend LC135 ke? I takut pasal No.1 bike that kena stolen
8. How is the crankshaft bearing ? Ade bunyi? banyak motor LC135 kena overhaul pasal crankshaft bearing loose and producing knocking inside gear box ?
9. motor kau bila bawa laju ade vibration from footrest ? ade vibration from fairing cover ? ade vibration from bandle bar ?
v2
g88
Posted 19 August 2009 - 12:31 PM
g88
    Duke of Hazzard
  • PipPipPipPipPipPipPip
  • 48,280 posts
mine just 4 years old this month and only hitting around 17K++ Km so far. Recently change rear brake pad and tires....plug changed once during 10K or 15K KM....engine service each 1000KM.
Since 13K km started using Motul Full Sync 10W40...which i only change after 2000KM...am thinking might wanna switch back to 1000KM service again smile_big.gif
mitsu4g18
Posted 19 August 2009 - 01:01 PM
mitsu4g18
  • 1,891 posts
QUOTE (g88 @ Aug 19 2009, 12:31 PM) <{POST_SNAPBACK}>
what about your chain & sprocket, how many time already you change?
benji
mitsu4g18
Posted 19 August 2009 - 01:04 PM
mitsu4g18
  • 1,891 posts
benji
limking
Posted 19 August 2009 - 02:33 PM
limking
  • 2,887 posts
QUOTE (reuters32 @ Aug 19 2009, 11:22 AM) <{POST_SNAPBACK}>
excellent lim king
i am in tampines.
more questions
No
140 km mileage uses around 3.3 litre if speeding above 120-140km/hr all the way & below 2.8 litre if going at below 120km/hr
Last bike was HONDA EX 5 ,using Shell VSX oil so far so good till changes to Sharlu oil then there wherethe trouble starts . Now only trust Shell VSX oil and no others .
4. u have givi box?
No . Dangerous in JB coz lot of people kena robbed which the robbers pushes the box when you're riding and then you drop .And that's it . Also handling on cornering not so good if have box behind .
Using Osram halogen .Cheap and good .Can last around more than 6 months & only RM 8- RM 10 depending on certain shop
Scare bike kena stolen then try some preventing matters like havinga good solid padlock for your sporkets .
Mine all o'kay . No bunyi yet . Maintainance important .
Kalau bawa max macam 140km/hr ke atas then bahaya lah .Pernah cuba bike macam lambung/ floating dan handle vibrates kuat .Fairing cover vibration comes from loosen nuts/screws .
