But after looking at what you had posted in your blog interms of the size & specs of new 4008..i believed this new 4008 are not excatly 100% the same as ASX but only partially body parts or trims are sharing with Mitsubishi, correct me if i'm wrong.
Correct, not 100% the same, as you can see Peugeot have basically designed a new outer shell and interior, used the Mitsubishi ASX platform (GS) and powertrain for certain markets. I believe they will have more 'Peugeot' options engine wise in Europe. Guess, we'll find out more in March during the Geneva Motor Show.
The way to combat obnoxious ideas is with other ideas. The way to combat falsehoods is with truth.
OK.. but i thot 4008 are used the 4007 platform and with reduced the front & rear diamension, and from my understanding 4007 platform are used same as Mitsubishi outlander, so wonder why you said 4008 are used ASX platform ?
edited : OK...i just got my answer, you are right ASX platform are same as outlander , ASX platform are also been modify from outlander platform same as 4008.
