Hyundai Avante 2010 X20 Heating Up + Aircond Not Cold
ayluvb3ech
Posted 25 July 2014 - 04:59 PM
ayluvb3ech
  • 709 posts
QUOTE (raymondcn @ Jul 23 2014, 03:05 PM) <{POST_SNAPBACK}>
Thank you "ayluvb3ech" . You are spot on!.
Keep up the good work.
thanks.
even if you don't know about cars, there's 1 tip i recommend in order for you not to get conned.
Always remember to change items of low value first.
Eg.
Car overheating - Check coolant, then check radiator cap, then check thermostat, if cannot then only switches/relays/sensors and lastly fan.
Car jerking/Gearbox hunting gears - change spark plugs, then change spark cables, then replace ATF, check plug on coil or distributor for cracks and finally replace GB.
Power window not working - check fuse & switch, then only motor.
More often than not, mechanic already know what are the problems. But they tend to slaughter u with the highest value item first.
Hyundai Sonata NF 2.0 (G4KA)
kelvinhunt
Posted 11 August 2014 - 09:18 AM
kelvinhunt
  • 60 posts
Thanks AYLUVB3ECH,
Anyway problem was solved by replacing both the cooling fan and resistor which looks like a plug connector (connecting the fan and the electrical supply.
Total cost was Rm 663.95, breakdown as follows;
1. Motor radiator resistor - RM95.90
2. Motor radiator cooling fan (25386 2H051) - RM 528
3. Labour (0.6 units) - RM 37.80 (after 10% disc)
4. Service tax 6% - RM2.27
Thanks all
Kelvin
