The NGK Laser Iridium spark plugs are suitable for both THP and VTi engines. These are the stock spark plugs chosen by BMW for Mini John Cooper Works engines and Peugeot for THP200 engines because of their superior ignitability, stable idle, superior anti fouling, improved fuel efficiency and lower emissions. The stock NGK/Beru platinum spark plugs need to be changed every 40,000km. In contrast the NGK Laser Iridium spark plugs have almost twice the longevity, rated to last 80,000-100,000km by NGK. The price for a set of four spark plugs is RM220, inclusive of shipping charges.
The K&N air filters are high performance drop-in replacement air filters. Compared to the stock paper air filter, the K&N air filter provides optimum performance and filtration for smoother acceleration and better fuel economy. What also make these filters better than stock air filter, besides having better filtration, is they are washable and reusable. Just take them out very 80,000km (depending on driving conditions), using the K&N Air Filter Care Service Kit to clean and re-oil them and they are good as new. They are being backed by K&N Million-Mile Limited Warranty. Making them the last air filter you would ever need for your car, in comparison stock air filter has to be changed every 40,000km.
K&N Air Filter
Peugeot 308 THP140/156
Peugeot 408 THP163
Peugeot 508 THP156
Peugeot 3008 THP156
Peugeot 5008 THP156
Peugeot RCZ THP156/200
Price: RM210
K&N Air Filter
Peugeot 208
Peugeot 308 VTi
Price: RM245
K&N Air Filter
Peugeot 407 2.0
Peugeot 408 2.0
Price: RM220
Message me if you want prices for other models not included on the above list.
Price: RM70
NGK Laser Iridum Spark Plugs
Product Description
NGK Laser Iridium spark plugs provide superior ignition and longer service life. It is constructed from durable material that is corrosion and abrasion resistant. Smallest tip diameter available Iridium/Platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions.
- Laser welded Iridium center electrode tip
- Platinum disc welded to backside of ground electrode provides long life
- Trivalent Metal Plating for superior anti-corrosion and anti-seizing
- Faster starts and quicker acceleration
- Better fuel economy and lower emissions
- Best OEM Iridium spark plug available
- Original Equipment Manufacturer approved design
K&N High Performance Replacement Air Filter
Product Description
K&N's high performance replacement air filters, made in the U.S.A, are designed to increase horsepower and acceleration while providing excellent filtration. There is a great deal of engineering behind every K&N Filter. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N, requires no modifications.
Product Description
A six-step maintenance system designed to clean any K&N air filter. Restores maximum air flow efficiency so your K&N air filter performs like new. Contains one 8 oz. squeeze bottle of air filter oil and one 12 oz. bottle of air filter cleaner.
