Bolt-on Turbo for waja
wajon
Posted 04 June 2007 - 01:34 PM
wajon
  • 25 posts
hello to all my buddies..
I hav a few question related to bolt-on turbo for standard waja..
here goes my question:
1. I owned a waja 1.6(A) 01, and nvr do any mods for it.. recently i
found a workshop at johor jaya tat they do bolt-on turbo for waja which
will coz me around 5-7k.. i always wanted to hv a turbo engine for my
waja, i should go for engine swap or juz bolt-on turbo for it?
2. Will it be any side effects if i bolt-on turbo for my standard engine?
3. What others mods should do after i bolt-on turbo?
4. Anyone hav done bolt-on turbo pls share ur knowledge and experience..
Thank u all..ur comments will be appreciate.hv a nice day :)
baldwin
Posted 04 June 2007 - 02:23 PM
baldwin
  • 2,093 posts
a standard Waja engine wont be able to take the pressure of a turbo
charger...but i guess the $5-7k they quoted u includes replacing pistons,
valves, cams, manifolds...and all other "heavier" duty engine parts..
wajon
Posted 04 June 2007 - 04:15 PM
wajon
  • 25 posts
yeah.. they did include those stuff u mentioned..
izzit still worth it?
ndsummer
Posted 04 June 2007 - 05:13 PM
ndsummer
  • 64 posts
i don't think so they change the piston and valve / as i know they add in
turbine, maniford, injector, BOV , intercooler, boost and fuel
controller, additional they might also change the casket fort more
compression.
N4Speed
Posted 04 June 2007 - 06:47 PM
N4Speed
  • 1,901 posts
yalor,...4G18P N/A kena pressure by Turbo,,..i think not very advisable
lar....will reduce yo engine lifetime only... why dont u do engine
upgrade?..
meaning, swap to a 4G63 easily lar,,in terms of power aso better than
BOLT ON performance,..
can masuk WAJA engine bay no sweat arr... a little bit costly lar...
wajon
Posted 05 June 2007 - 10:46 AM
wajon
  • 25 posts
thanx for ur advise..
but having a halfcut engine oso very risky..coz dun noe wat happen inside
the engine.. problem only occur after pasang it a few months later..
plus got ppl use it oledi for 1 year..no problem occur.. i think is ok
lo.. the work shop oso quite famous in terms of their workmanship..they
oso do good racing cars..
mulli
Posted 06 June 2007 - 04:14 AM
mulli
  • 206 posts
i have talked to a few mechanic, best option is to swap engine.
you need to find a reputable workshop/mechanic to do the swapping.
these guys will source the best working condition engine for you.
wajon
Posted 06 June 2007 - 10:55 AM
wajon
  • 25 posts
owh...so i better giv up having turbo kit for my waja...
sigh.. scared oso its engine blown..
tstai77
Posted 06 June 2007 - 01:58 PM
tstai77
  • 74 posts
How about SuperCharge?
I think it's weaker then turbo but it should be cheaper then bolt-on
turbo & it's more compatible with NA engine. No need intercooler, etc...
I've seen them in oversea magazine on other car but it never these device
in M'sia?
wajon
Posted 06 June 2007 - 02:05 PM
wajon
  • 25 posts
dunno le..
i oso nvr heard any workshop that they do super charge for NA...
but last time i saw a vtec using supercharge..dunno whr he do tat..
