Car Battery
Posted 07 April 2006 - 07:35 PM
  • 71,444 posts
Hi adnoc,
Regarding the VS. Initially was doubtful whether it worked or not. I have
been following the VS thread in this forum for quite sometime, until
finally I fitted one also.
The most difference I can find is that my audio definately sounds better.
The bass is stronger and the overall sound clearer.
I have a boost meter fitted earlier. Before fitting VS, every time I switch
on the headlights, it dims slighty and when switch on the spot light, it
dims further. But now, when switch on the headlight, the meter will dim a
moment (like a bling of an eye) and will brighten up again, same goes when
switch on the spot light, however the headlight are not brighter as some
others have mentioned.
Engine also seems to be running smoother.
rdgs,
#32
Posted 09 April 2006 - 09:47 PM
  • 71,444 posts
Have completed my grounding DIY yesterday, now boost meter does not even
bling, when on headlights or spotlights.
rdgs,
#33
clausman
Posted 10 April 2006 - 12:28 PM
clausman
  • 14 posts
am wondering, where to check wat is my car maximum recommended amperage?
from car manual book?
#34
push
Posted 12 April 2006 - 12:51 PM
push
  • 1,552 posts
hi guys,
i wanted to change
d battery but dont
know which type to
go for
shud i get MF or
d normal battery?
wat brand is d most
reliable - GP, Bosch,
Yuasa, Century?
#35
jhlk99
Posted 12 April 2006 - 03:27 PM
jhlk99
  • 472 posts
> Yours 1997 model is it?. If I had kept my original battery then my 1996
> A6 would have lasted 10 years by now
Yes, early 1997. The car was actually manufactured at the end of 1996.
There is a battery voltage gauge on the dashboard that allows me to
monitor the state of the battery easily so I have no fear of a dead
battery. Not that I do much monitoring.
Jonathan
#36
Etrec
Posted 12 April 2006 - 03:59 PM
Etrec
  • 300 posts
Yah!
I've got the same gauge too on my dashboard. So I guess I'll use the
battery until there is a significant drop in reading.
#37
jhlk99
Posted 12 April 2006 - 05:28 PM
jhlk99
  • 472 posts
Mine currently reads 12V after sitting overnight but I have measured the
battery voltage directly and it read 12.4V so my voltage meter is slightly
off. That's low but the car works fine.
I suspect that the low voltage is due to dilution of the electrolyte and
am waiting for it to concentrate again as water evaporates. I have a
simple hydrometer to measure electrolyte density.
Jonathan
