Yamaha Nouvo LC 135
whathef
, Sep 06 2008 09:41 PM, 95 replies to this topic
#31
Posted 03 October 2008 - 02:21 AM
Both.
Mostly normal speed, around 60 to 80kmh with intermittent short burst to
properly load the piston & rings. already changed the engine oil (mineral)
at around 100km mileage and saw small metal particles came out. i wonder
why most original manufacturer recommend first oil change at 1000km while
the particles at 100km already very obvious. These particles sure worn
bearings and other internal component very fast.
i reserve the full throttle until after 1000km. That one i follow
manufacturer.
manufacturer.
#32
Posted 04 October 2008 - 09:04 AM
Mine already past 1000 mark.Change oil for the 1st time...the feeling was
great especially now i can go beyond 100km/h.Tried 120km/h this bike is
still steady.Good buy for me!
#33
Posted 06 October 2008 - 08:13 PM
"...i wonder why most original manufacturer recommend first oil change at
1000km while the particles at 100km already very obvious..."
maybe this site can give answer.
#34
Posted 10 October 2008 - 02:25 AM
Thanks for the link.
The bike has done almost 500km. now everything seems to be smoother. The
engine felt lighter. and now i think the midrange power is much similar to
elegan. but this one handles much better than elegan. fully satisfied so
far.
far.
#35
Posted 10 October 2008 - 07:37 PM
bro, what (mineral) oil brand do u use when changing at 100km?
#36
Posted 13 October 2008 - 12:38 AM
brand total 4t basic.
actually this nouvo lc engine can tolerate with wide range of engine oil
as the recommended engine oil is 20w-40, the most grade available in the
market. usually scooters requires higher grade engine oil such as 10w-40
which usually more pricey (mostly cost more than rm18 per litre). i
believe Nouvo lc will perform better with 10w-40 or even 5w-50.
some modern bike requires 10w-40 as they equipped with oil filter but
nouvo lc didnt use one. oil filter will increase servicing cost and
couldnt tolerate with thicker oil such as 20w-40.
#37
Posted 13 October 2008 - 12:17 PM
total 4t basic? never heard of it
"some modern bike requires 10w-40 as they equipped with oil filter but
nouvo lc didnt use one."
do u mean nouvo lc don't have an oil filter like 135lc?
#38
Posted 14 October 2008 - 02:19 AM
correct. nope.
it only has mesh filter which in short never need replacement. same like
elegan's.
scooters are usually high rotation engine. adding an oil filter might
restrict its rotation (oil became heavy) and giving it higher resistance.
plus low cc = limited top speed. for example elegan (without oil filter)
could rev outmeter (more than 10k rpm). this nouvo lc dont have an rpm
meter.
elegan's.
meter.
