#101
Posted 19 September 2011 - 01:12 AM
I have a 2005 G2 Harrier 300G, and can I ask is it normal for the gear not shifting to 5th gear when just cold start in the morning? Every morning when the engine is still cool, I start the car and straight away drive out. It does not shift to 5th gear unless the temperature of the car rise up to almost half then the gear will shift to 5th. Is this normal or something is wrong with the gearbox already???
I think it's quite normal since ATF not reaching normal operating temperature.
If you're worry why not go for a flush in your gearbox and replace with the correct fluid. Use only Toyota ATF.
Ram me if you can!SplitFire
#102
yzheng180
Posted 19 September 2011 - 03:38 PM
yzheng180
Oh~~~ I thought there was something wrong with it. I just flushed the gearbox last 8000km ago, and I used the genuine Toyota ATF~ Thanks for your info~~ Was google-ing around but didn't found any answer.. Thx ~ Anyways another 3 more question is,
1. Does the ECU in the harrier will know how to adapt to drivers habit like some other cars?
2. Does the ECU control the idle Rpm for most newer Toyota cars with ECU? and is there any other components that is controlled by the ECU? because I realize when I replaced my car battery without letting the engine running will cause everything in the car reset, (such as all auto power windows I've need to set it before all windows can be used as Auto)
3. My brother have a G1 Harrier 3.0 FOUR, does the ECU controls the idle rpm too? His car idle will be very low until its air-cond is not even cold....
#103
granddamd
Posted 10 November 2011 - 01:25 PM
granddamd
5th Gear
harrier lexus black bison wald bodykit spoilerwe provide this full set wald black bison body 350rx latest lexus parts kits in malaysia. pls cal 010-3666575 for more info
this bodykit is full FRP material ,no rivette is require... good fit..just plug and play simple with rubber lining strip like original looks
#104
fudeenzz
Posted 13 November 2011 - 01:58 PM
fudeenzz
hi..
Do you have bodykits as such for 1st gen harrier?
Im planning to buy a 1st gen toyota harrier as i traveled a lot and i need comfort,safety and a reliable car(and not so expensive).
#105
voodooooo
Posted 05 January 2012 - 12:17 PM
voodooooo
hi..
i have the 1st gen harrier bodykit...please join us at
http://www.facebook....8...&permPage=1
