Exora Bold Engine Sound Question
Posted 02 February 2012 - 02:14 PM
I got my new exora bold CFE a few weeks ago. This is my first time driving an MPV.
I noticed that when I start my engine, put in the reverse brake, but still hold on to the brake pedal (i.e. car not moving, gear in reverse already), I can hear the engine sound coming from the left side dashboard, something like 'woom...woom...woom...woom' (repeatitive, like something oscillating). Once I release the brake (car starts to move), or if I put into neutral gear, then the sound will gradually fade away.
Is this something i should be concerned of? Is it normal?
I suspect is sound from torque converter?
Regards,
CK
Posted 03 February 2012 - 05:36 PM
Regards,
CK
There could be turbo pressure cut in into cylinder without any lockup with torque converter..it seems the ECU didnt tell the turbine pressure not to work at the moment.
Might be the design is like that . Turbo all round even in reverse gear. Still thinking to get this MPV though afraid of the turbo not properly fit in and programmed.
Something to check with OBD to find out the error while putting gear in R...then will see what s problem. If not, the design is like that !
Posted 04 February 2012 - 11:50 PM
Regards,
CK
i didnt notice that woh.
Posted 06 February 2012 - 09:01 AM
Regards,
CK
once i drove friends flx cvt . put reverse before the engine is up to operating temperature and its sounds like so. maybe the system is trying to maintain the idle repeatedly in conjunction with the load given by the transmission when the engine is still cold. vom vom is safer than voooooooom that it might push or surge the car or extra effort on brake.
just guessing. the right answer should be well explained by proton engineer somehow.
Posted 07 February 2012 - 12:01 PM
so far 2 CFE kena alr... still cant figure out wat happen?
mine dont have this sound.... touchwood.
http://www.youtube.c...player_embedded
http://www.youtube.c...eature=youtu.be
Posted 07 February 2012 - 12:19 PM
Seems like something is touching. It sound only during starting which means it only rub against each other during the engine vibration at start up. Sound scary....hehe.
IMHO not hard to solve.
Doesn't sound like steel though.
Posted 07 February 2012 - 12:38 PM
Posted 07 February 2012 - 03:20 PM
after chg lub also same problem... SC mech still cant find the real cause.
Posted 07 February 2012 - 04:13 PM
1 cent
Cheers
