Am owning a 12 year old Waja auto drive. After a stormy raining night, I found the front and back floor carpets wet. On checking the roof inner layer (which is cloth material) I found it dry. So the roof does not seem to be the problem.
Could those with experience of water seeping into their Waja share how you found the solution? What can be done to find the source of water seeping in ?
Waja Floor Carpets Wet
andlfloh
, Aug 17 2014 05:20 PM, 2 replies to this topic
Posted 05 September 2014 - 07:12 AM
QUOTE (andlfloh @ Aug 17 2014, 05:20 PM) <{POST_SNAPBACK}>
check the glass seal on your window.
the rubber is called run channel.
Posted 15 September 2014 - 04:53 PM
I had similar problem but with wet front passenger carpet.. Problem is related to aircond drip hole external tube missing, this allowed back flow of water when driving... Sometimes stuck open vent for external air circulation will cause problem as well. Stuck due to small leaves, branches preventing the vent to properly close...
Mych
