Ampang
My experience shows that on hot days (temp over 38 C), the car usually no power as hot air is less dense and hence less oxygen than cooler air. Furthermore turbo exhaust will heat up the the compressed air even more. The intercooler maybe not very efficient to cool down heated air.
Not sure what the software upgrade does, but ifit is to prevent knocking means aggresive ignition retard when ping is detected OR make the fuel richer. I assume it will retard as make fuel rich will cause the 2nd O2 sensor to throw a fault code. This means lesser power.
I have learnt to drive sedately during hot weather and with heavy load. This helps to reduce engine knocking.
jmkoo.
Thanks for your info.
My car issue, even tem below 30'C also having the same issue.
The only way to make my car torque temporary back, is to high speed driving in highway for 20 mins, but the torque back wont last long, maybe a week.
My case sound like carbon build up issue. But I also suspect :
- Last time my HP pump faulty, when send to NASIM, while they replacing the new pump for me, im not sure they mount back those pump for me properly or not, I feel that, it could be petrol injection issue.
- Could be the 'Software upgrade' issue, before they replace the new pump for me, they erase the ECU error and did the software upgrade for me, from there, the pulling power already become one kind.
I'm not good in car engine , above matter i'm just guessing, but it make me sick.
My car just clocking 60,000km, warranty off. Im sending to KS for servicing' at the same time will check the issue, hopefully KS have the original map for these car, so we can test whether is the software upgrade issue or not.
( I heard mechanic said, the software upgrade is actually to de-tune our prince engine, so when running on RON95, even the petrol is not good enough for our engine, it won't make our engine have bad cough (Knocking).
