| Autoworld.com.my |
Jan 24 2009, 08:06 AM
Post
Driver ![]() Group: Members Posts: 41 Joined: 15-February 05 Member No.: 44,944 |
CNY greetings to all, Most appreciate for any can help to diagnose this problem. Car : Honda Accord SM4, 1992, Auto Transmission (Local, Kah Motor) Lately, the speedometer reading and auto trans are both behaving in an erratic manner. At below 40 kph, both behaving perfectly with the gear change as appropriate when accelerating from 0 to cruising at lower than 40 kph. But when speed increase above 40 kph, the speedometer reading will go wild, swinging to beyond 120 kph even when the speed of the car is only about 60 kph. At the same time, my auto trans will start misbehaving - I suspect that it couldn't figure out which gear it should be in. I suspect that there must be a sensor somewhere which feedback to auto-trans/speedometer and that probably is now malfunction. My mechanic could find it. Bros - can advise where is this sensor or if my deduction is wrong, please share your experience, Thanks --------------------
goBetong
Jan 24 2009, 12:23 PM
Post
![]() Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 2,685 Joined: 8-August 07 Member No.: 67,618 |
for such an old car, i can only suspect 3 main culprits.
1. valve body. often ignored, get it removed. serviced and cleaned. then blow with air pistol all the clogs inside. 2. clutch plate - this is of multiple wet type, just like in a kapchai. if worn out, need to be replaced. 3. ECU - for cars with electronic controlled overdrive (unlike the 3 speed saga/iswara/kancil), the ECU plays a vital function in overall transmission function. other than that, use the proper ATF specified by the manufacturer and make sure the gearbox internals are clean inside. once u have done the basics, then only can look at the speed sensors and such. this job is not for conventional mechanics. -------------------- ![]() |
Jan 25 2009, 12:27 PM
Post
![]() Forum Ninja ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 64,192 Joined: 11-November 04 From: Petaling Jaya Member No.: 41,856 |
CNY greetings to all, Most appreciate for any can help to diagnose this problem. Car : Honda Accord SM4, 1992, Auto Transmission (Local, Kah Motor) Lately, the speedometer reading and auto trans are both behaving in an erratic manner. At below 40 kph, both behaving perfectly with the gear change as appropriate when accelerating from 0 to cruising at lower than 40 kph. But when speed increase above 40 kph, the speedometer reading will go wild, swinging to beyond 120 kph even when the speed of the car is only about 60 kph. At the same time, my auto trans will start misbehaving - I suspect that it couldn't figure out which gear it should be in. I suspect that there must be a sensor somewhere which feedback to auto-trans/speedometer and that probably is now malfunction. My mechanic could find it. Bros - can advise where is this sensor or if my deduction is wrong, please share your experience, Thanks Is your speedo cable driven? If so, then could be meter problem. Auto Gear problems can be plenty, from fluid problem, to clutch plate and others. Not sure whether your auto is driven by TCU (Transmission control Unit) as in my old Auto Mitsu. Could be that also..... -------------------- ![]() |
Feb 8 2009, 07:32 AM
Post
Bros', Would wish to share this info with fellow petrol heads who may encounter the same problem. I changed the Speed Speed ($200.00) and the car now runs like a dream. It's just a two nuts and screw driver job, but you will have to take out the intake manifold/others to access it. The main difficulty was finding where it is located (back of auto-trans, engine closer to the firewall). Solenoid Valves Since my car is aged (> 250,000 km), I suspect the two Solenoid Valves on the auto-trans need to be changed too. But how to you tell or test whether they are working or not working fine? Bros' would appreciate any pointers here. Thanks --------------------
goBetong
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 24th May 2013 - 03:55 PM |
