| Autoworld.com.my |
Jan 21 2009, 10:57 AM
Post
Advanced ![]() Group: Members Posts: 85 Joined: 10-March 03 Member No.: 25,685 |
Hi Sifu sekalian,
My wira 1.6xli check engine light is on and off during driving. The check engine light will on for few seconds during driving and off later. Any idea what wrong it that? By the way, my car does look fine as no jerking and etc. I'm wondering whether need to send it to service center to check the engine tuning. Thanks. |
Jan 21 2009, 11:28 AM
Post
Fast & Furious ![]() ![]() ![]() Group: Members Posts: 2,093 Joined: 7-June 01 From: N9 Member No.: 50 |
do send it in as it could probably be one of the sensors giving way already..
Jan 21 2009, 01:30 PM
Post
Jan 22 2009, 01:05 AM
Post
White Lightning ![]() ![]() ![]() Group: Members Posts: 7,718 Joined: 27-January 05 Member No.: 44,304 |
thx for the replied. normally how much do I need to spend if the sensor faulty? does it relate to the Throttle body? you know how to read the code? http://www.idmoc.com/Download/MITSUBISHI%2...0DIAGNOSTIC.pdf -------------------- Mych
Jan 22 2009, 07:16 AM
Post
![]() Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 3,042 Joined: 18-May 08 From: johor bahru Member No.: 73,225 |
Last time, my car jerk (+engine light on) with engine going to shut of during cruising
Then went to workshop check found the positive terminal loose, tighten it. Now so far no problem -------------------- ![]() ![]() |
Jan 22 2009, 06:10 PM
Post
Veteran ![]() ![]() Group: Members Posts: 173 Joined: 22-January 09 From: selangor Member No.: 77,697 |
hey guy...i'm having da same problem in my 1996 wira 1.6XLi... da check engine light is on and off after few minutes... went to proton servis center for scanning...and da error codes are 'ignition coil open' and 'knock sensor'...replaced with second hand knock sensor but it still come out... and my car hav serious jerking prob... it will then suddenly die off and very diff to start da engine again....can u guys help me with it?
Jan 22 2009, 07:00 PM
Post
hey guy...i'm having da same problem in my 1996 wira 1.6XLi... da check engine light is on and off after few minutes... went to proton servis center for scanning...and da error codes are 'ignition coil open' and 'knock sensor'...replaced with second hand knock sensor but it still come out... and my car hav serious jerking prob... it will then suddenly die off and very diff to start da engine again....can u guys help me with it? I just send my car to service center today and they've check the tuning with MUT-II. They claim got error code saying the air flow to ekzoz got problem and have reset the code and spray some cleaner to clean the TB. Total spend is RM70. I'm monitoring it now whether the problem resolve or not else have to send back for them to check. beemc, i'm not sure what ur problem is. It may relate to your TB because I've my car jerking during driving and die off when waiting for traffic light few years back. I've send my car to check then they've changed the ISC gear in the TB but it won't last long. After 3rd set of ISC gear been changed but it happen again, so I decide to change a new TB and it last me for few year till now before i got this check engine light on and off intermittent during driving.(Touch wood) |
Jan 23 2009, 04:37 PM
Post
I just send my car to service center today and they've check the tuning with MUT-II. They claim got error code saying the air flow to ekzoz got problem and have reset the code and spray some cleaner to clean the TB. Total spend is RM70. I'm monitoring it now whether the problem resolve or not else have to send back for them to check. beemc, i'm not sure what ur problem is. It may relate to your TB because I've my car jerking during driving and die off when waiting for traffic light few years back. I've send my car to check then they've changed the ISC gear in the TB but it won't last long. After 3rd set of ISC gear been changed but it happen again, so I decide to change a new TB and it last me for few year till now before i got this check engine light on and off intermittent during driving.(Touch wood) thx bktang...i'll consider bout da TB... but da mechanic said most probally is the distributor... i hav changed a re-cond distributor few yrs ago due to da same jerking prob... after changing it... da prob solved... but now... da mechanic not sure izzzit bcoz of da distributor again... |
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 23rd May 2013 - 09:01 AM |
