Autoworld
Autoworld.com.my
> Wira Se Owner - Need Advice
philmr21
post Dec 29 2008, 03:10 PM
Post #1
Group: Members
Hi, need advice. Any comment if I change my Wira SE rim to new Saga rim? Is it not too light? Thanks
Go to the top of the page
+Quote Post
drexchan
post Dec 29 2008, 09:11 PM
Post #2
Hot Rod
Group: Members
Different PCD. It won't fit.
However, it will only do good than harm to have lighter wheels. Nothing is too light for wheels.
+Quote Post
post Dec 30 2008, 10:13 AM
Post #3
Group: Members
QUOTE (drexchan @ Dec 29 2008, 10:11 PM) *
Yup, Different PCD. Wira's are 100, and Saga are 114.3
If you need light weight rims, you have to check out aftermarket rims, as OEM rims are normally the heavy weights....
Look out for the offset also....
rdgs,
+Quote Post
philmr21
post Dec 30 2008, 12:24 PM
Post #4
Group: Members
QUOTE (vr2turbo @ Dec 30 2008, 10:13 AM) *
rdgs,
mind asking what is PCD? Can u guys suggest what type/brand of rims is suitable and best for wira SE?
my bugdet is < RM1500. The reasons why I wanted to change rims is to reduce the fuel consumption. Besides, smaller rims cost less expensive tyres also. Thanks!
+Quote Post
post Dec 30 2008, 06:45 PM
Post #5
Group: Members
QUOTE (philmr21 @ Dec 30 2008, 01:24 PM) *
PCD = Pitch Centre Diameter, it's the diameter of a circle which passes through all the bolts' centre-point.
http://www.needforspeed.co.uk/htmlpages/TechWheels.htm
Hope this can help you understand more....
rdgs,
+Quote Post
YSW
post Dec 31 2008, 12:58 AM
Post #6
Group: Members
You can go for 195/55/R15 or 195/50/R15 tyres with 15" rims instead of your ori 205/45/R16. You might feel a bit lighter but could be only little advantage on FC.
I would suggest tuning the step and TPS, service throttle body, tappet adjustment, lower viscosity engine oil, service a/c compressor and etc might be able to do more good on FC
+Quote Post
post Dec 31 2008, 09:39 AM
Post #7
Group: Members
QUOTE (YSW @ Dec 31 2008, 01:58 AM) *
If use Saga rims, then down to 14" only.
Better take YSW advice on 15", but won't look as good as your 16" rims/tyres....
rdgs,
+Quote Post
DSAI
post Jan 19 2009, 12:06 PM
Post #8
Group: Members
lower viscosity engine oil= may i know what is the best oil gred for wiras 10W\40W?thanx
a new hope...
+Quote Post
post Jan 19 2009, 01:57 PM
Post #9
Group: Members
QUOTE (DSAI @ Jan 19 2009, 12:06 PM) *
If you need lighter, can go to 5w-30.
Why don't you post to "Petrol, Oil & Additive" Thread for more answer....
rdgs,
+Quote Post
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 2nd March 2015 - 03:20 PM
