| Autoworld.com.my |
Sep 29 2005, 04:52 PM
Post
Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 2,689 Joined: 23-February 05 Member No.: 45,264 |
I just inherited a 6 year old Kancil 660 EX (Manual) - I encounter
steering groaning whenever I turn the steering. Sound like joint needs greasing or worn gears. This 3-cylinder Daihatsu carb engine is also very harsh and jerking (especially pick-up on 1st gear while releasing the clutch). I have just change to Petronas Syntium 3000 & change 3 spark plugs. Anybody has this problems as well? Care to share or any solution ? |
Sep 29 2005, 07:19 PM
Post
Fast & Furious ![]() ![]() ![]() Group: Members Posts: 1,370 Joined: 9-January 01 From: Shah Alam Member No.: 2,215 |
Steering gives out sound when turning it while moving or is it when not moving? If when got sound while turning+moving+accelerating then your CV joint dirty/worn already. Ask mechanic to check the rubber boot and see whether it is leaking grease. If engine jerking when accelerating, maybe contact point (pak kam; platinum in cantonese) needs changing. If contact point still new, check other ignition related system; distributor, HT coil, spark plug cable etc... Regards. |
Sep 29 2005, 07:53 PM
Post
Road Warrior ![]() ![]() Group: Members Posts: 874 Joined: 10-September 05 Member No.: 52,028 |
The 660cc is a little harsher than the 850cc..and the bigger brother 1000cc
Kelisa,Kenari`s engine is even harsher...but more power. Kancils have famous ball joint problems when turning left or right..they worn out very fast..even u change to half cut ones..also will come back months later. Jerking ler..this engine has contact point (but I heard newer generation of Kancil engines are electronic ignition) ..check if it`s worn off already.. But the good part about Kancil 660cc (or rather with 3 cylinder Daihatsu engines) is that they are spirited in nature..and very economical in city driving (but highway,FC may par with bigger cars as it runs very high rev) BUT try taking it on the highway..thats where it`s weakness shows..except 1000cc.AND..it runs out of breath (torque) fast for kancil 660.Thats why at around 70km/h..it starts to feel `lethargic`. Try carrying more people and will even show more `lethargic`. I tried ta-pau a Wira on traffic lights..and it screams hard but performs badly. |
Sep 30 2005, 09:13 AM
Post
White Lightning ![]() ![]() ![]() Group: Members Posts: 6,135 Joined: 9-April 02 Member No.: 19,559 |
just change to electronic distributor, no need to change the contact
point regularly, the jerking can be very irritating at times the kancil 660 FC is still the best, easily 17km/l but crampy, bumpy and zero ride comfort |
Sep 30 2005, 04:27 PM
Post
![]() Taxi Driver ![]() ![]() Group: Members Posts: 393 Joined: 21-April 05 Member No.: 47,322 |
what about the new kancil 850 manual? ok or not? i feel it's quite ok to
drive around also .... it's more economical compared to kelisa 1.0 M, rite? |
Oct 1 2005, 03:57 AM
Post
Ah Steering ball joint need to grease. Sounds like my Kancil needs it. I
was told the rear wheel bearing also need to grease as well after 40,000km? Can I buy "Pak Kam" myself and DIY? Can you explain how to change it? Many thanks guys. |
Oct 3 2005, 03:16 AM
Post
I still encounter a shudder or jerking when in 1st gear picking up.
Otherwise, once the car is running, its quite nippy and agile. Quite eager to run too. |
Oct 3 2005, 10:32 AM
Post
give mechanic to do ler, u need to know how to set the contact point gap
ler, set wrongly will also jerk one, the best is to change to electronic distributor, plenty of them in breaker yard |
Oct 3 2005, 10:39 AM
Post
one more thing, always buy oil filter from P2 SC only, those oil filters
sold outside are most likely fake ones, even if it comes wif that 3D sticker, and based on my experience, there is power loss if u use fake oil filters |
Oct 3 2005, 12:38 PM
Post
5th Gear Group: Members Posts: 5 Joined: 30-September 05 Member No.: 52,633 |
I got Kancil 850A 7 years old,recently got very strong smell from
the exhaust pipe ( i think is Carbon kot ). Any one face the same problem ? |
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 20th June 2013 - 03:13 AM |
