| Autoworld.com.my |
Oct 29 2005, 07:56 PM
Post
Probation ![]() Group: Members Posts: 22 Joined: 26-March 05 Member No.: 46,460 |
hi sifus
can anyone tell me how to check the brake pads whether they need changing? mine is a Gen2 cos yeterday i drove 2km with the handbrake on so will the effect b bad t my pads.Thank you for any advice. |
Oct 29 2005, 09:25 PM
Post
Fast & Furious ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 28-November 04 From: selangor Member No.: 42,327 |
handbrake on means you gonna need to check your drum shoes. Need to open up
the cover of the rear wheel to see the shoes. |
Oct 29 2005, 10:10 PM
Post
what will I have 2 look for when I check the drum shoes?Sorry not very
experience in all this cos my first car really no nothing about all this stuff and thanks kelisa.and what does the drum shoe look like? |
Oct 31 2005, 12:24 PM
Post
Check the thickness. The link below shows what it looks like.
http://static.howstuffworks.com/gif/drum-brake9.jpg Gen2 has disc brakes at the back right? If so I wouldn't worry too much. It's the disc brakes that's supposed to stop the car and not the drum brakes. The drum brakes are meant for parking only in a car like yours. Even if used for braking (say in a Kelisa or Wira 1.3) it'll last maybe the least 1 year. |
Oct 31 2005, 11:24 PM
Post
thanks Kelisa
Nov 4 2005, 09:54 PM
Post
White Lightning ![]() ![]() ![]() Group: Members Posts: 7,718 Joined: 27-January 05 Member No.: 44,304 |
I got a "scare" on thursday when intending to replace the brake pads for
my mom's 2nd hand kancil.. when the drum brakes at the back were taken out, I could not help but to notice a lot of grease on the lower half of the drum, due to over lubrication and leaking wheel cylinder. No wonder whenever I press the brakes, the car seems to brake more on one side.. both the wheel cylinder were badly rusted and had to be replaced. The mechanic had to wash the drumb with lots of petrol and soap to remove the grease residue before fitting in the new pads... so point to note, esp buying 2nd hand cars with drum brakes, get it checked by another mechanic.. |
Nov 4 2005, 10:02 PM
Post
Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 2,689 Joined: 23-February 05 Member No.: 45,264 |
mych,
How old is your 2nd hand Kancil? |
Nov 5 2005, 08:41 PM
Post
![]() Forum Ninja ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 64,178 Joined: 11-November 04 From: Petaling Jaya Member No.: 41,856 |
Newkelisa,
"Gen2 has disc brakes at the back right? If so I wouldn't worry too much. It's the disc brakes that's supposed to stop the car and not the drum brakes. The drum brakes are meant for parking only in a car like yours." I think you are a bit confused. If the car has disc brakes on the rear, they will not have any drum brakes. The handbrakes works on the discs, as well as when braking. The handbrakes works by cable by pulling a lever, to pressure the disc pads onto the disc rotor. Same as in drums, when the lever pushes the brake shoe onto drum internally. rdgs, |
Nov 6 2005, 02:52 AM
Post
Fast & Furious ![]() ![]() ![]() Group: Members Posts: 1,760 Joined: 24-August 02 Member No.: 22,144 |
Certain disc equip rear brake uses drum too like W123 124 mercedes Eclass.
It uses drum for their parking brake and disc for their normal service brake. This is due to fix caliper can't or difficult to integrate with parking brake mechanism. |
Nov 6 2005, 08:23 AM
Post
White Lightning ![]() ![]() ![]() Group: Members Posts: 6,693 Joined: 7-October 05 Member No.: 52,810 |
It's true that some car have BOTH drum brake (for handbrake parking) and
disc brake (for normal braking). I used to have a 1989 Isuzu Trooper 2.8TD and that one only have disc brake for BOTH Parking & Braking. It gives endless problem with parking because the integration of Parking & Braking is too fragile and break easily. Then I upgraded to a 1999 Isuzu Trooper 3.1TDi and this one have BOTH drum and disc for Parking and Braking respectively. Work much better. Guess Isuzu realise the problem with the previous 2.8TD. |
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 23rd May 2013 - 04:07 PM |
